09-09-2020 #1
Separate threads for wood/router and metal/milling.
Is it possible to separate the threads.
Every time I want to look at something to do with CNC machining, I get loads of stuff about routing wood.
BrianLast edited by BDH; 09-09-2020 at 10:38 AM. Reason: Title did not appear in the post.
09-09-2020 #2
There are separate areas for Milling and routers. You are probably looking in the general Discussion area which is exactly that for general discussions about anything.
It's just that routers are more common on this forum than milling machines or Lathes so they appear more often.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
adhesive for wood and metal
By JEK5019 in forum Woodwork DiscussionReplies: 11Last Post: 18-05-2019, 06:44 PM -
Designing a Metal milling bushless Spindle
By Kevman in forum Electronic Project BuildingReplies: 18Last Post: 14-04-2013, 06:43 PM -
RFQ: Looking for Aluminium CNC Milling Service + Lathe Work (2 Separate Jobs)
By biketrialsdave in forum Projects, Jobs & RequestsReplies: 2Last Post: 19-02-2013, 04:06 PM -
Pros and cons of climb milling in wood
By Richie in forum Wood Finishing Tips & TricksReplies: 15Last Post: 14-06-2012, 05:09 PM -
WANTED: Wanted: Small Metal Work Milling Machine
By 07trb in forum Items WantedReplies: 0Last Post: 04-03-2011, 06:58 PM
