How do you arrive at that thinking? most things have the skeleton inside for strength of the main structure and appearance there would be very little point of having steel outside of Epoxy granite other than to cut down on resonance of a steel box frame you could fill the box with epoxy.
Phill
Edit: I would be tempted to go for No2 image
The Following User Says Thank You to phill05 For This Useful Post:
15-09-2020 #2
15-09-2020 #3
I believe it will, a fixed gantry has got to be more stable than a moving mass gantry, the only thing is you need more room for the moving table.
I have a fixed gantry and no problem at all.
Phill
16-09-2020 #4
Hi EZELab
Welcome to the forum.
I would like to point you to John McNamara's epoxy build( https://www.model-engineer.co.uk/for....asp?th=139042)
A very thorough and informative thread.
Kindest Regards
Mike
Sorry Guys didn't see the last couple of posts, was trying to find the link
The Following 2 Users Say Thank You to mekanik For This Useful Post:
16-09-2020 #5
Removed.
16-09-2020 #6
Did you not read the OP's post "The frame will be epoxy granite and a welded laser cut steel skeleton inside" you would not cast an epoxy granite frame then clad it outside with steel Box section Box section was not questioned totally different build.
Come on!!!
Take a look at this project: https://www.model-engineer.co.uk/for....asp?th=139042
Phill
16-09-2020 #7
Removed.
The Following User Says Thank You to Zorbit For This Useful Post:
BUILD LOG: Epoxy granite vertical mill build log
By Nick in forum DIY Mill Build LogsReplies: 60Last Post: 08-06-2020, 06:30 AM -
Large Format Epoxy Granite Gantry CNC - Looking For Feedback
By Max Maker in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2019, 04:57 PM -
BUILD LOG: DIY Epoxy composite gantry frame milling machine
By John McNamara in forum DIY Mill Build LogsReplies: 28Last Post: 03-08-2019, 04:22 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM
