    Removed.
  2. The Following User Says Thank You to Zorbit For This Useful Post:
  3. #2
    Thank you guys, Got it.
    But, In John McNamara's build he put a LOT of enforcement inside, Like this base photo.
Name:	28-01-2019 9-40-45 PM.jpg
    I saw a lot of EG builds, most of them puts some kind of enforcement inside.
    Is there some way to do it right, Or should I just put plates on the surface for bolting ?
    Could someone please explain?
    Removed.
  5. The Following User Says Thank You to Zorbit For This Useful Post:
  6. #4
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,987. Received thanks 373 times, giving thanks to others 9 times.
    Quote Originally Posted by Zorbit View Post
    I can't help feeling that the thermal expansion of epoxy concrete, typically twice as much as steel, is going to tie that machine in knots. I'm happy to be educated otherwise.
    This was something I failed to find any kind of definitive answer to.
    The conclusion I drew, was it can't be that big a concern, given there are some very big EG machines with linear rails mounted to them, with no apparent allowance for expansion. So if it's not off any concern over a couple metres, I doubt I'd worry about it on your typical home build.
    As for John's build, what I took from his internal structure, was it was more about keeping things in place during the pour/cast, rather providing much in the way of structural support. Remember in that photo, the outer steel plates are the actual mold and designed to be removed after curing, so they can be reused.
  7. The Following User Says Thank You to m_c For This Useful Post:
  8. #5
    Removed.
  9. The Following User Says Thank You to Zorbit For This Useful Post:
  10. #6
    I don't think so.! Some of the best and most accurate lathes and Milling machine in the world use Epoxy granite because of it's thermal advantages and the fact they can build in extra mechanisms ie: running coolant thru the frame to increase this even more. Kern for instance and the Bigger DMG Mori's etc all use EG for there frames.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  12. #7
    Removed.
  13. The Following User Says Thank You to Zorbit For This Useful Post:
  1. BUILD LOG: Epoxy granite vertical mill build log
    By Nick in forum DIY Mill Build Logs
    Last Post: 08-06-2020, 06:30 AM
  2. Large Format Epoxy Granite Gantry CNC - Looking For Feedback
    By Max Maker in forum Gantry/Router Machines & Building
    Last Post: 23-08-2019, 04:57 PM
  3. BUILD LOG: DIY Epoxy composite gantry frame milling machine
    By John McNamara in forum DIY Mill Build Logs
    Last Post: 03-08-2019, 04:22 PM
  4. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  5. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
