    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    Quote Originally Posted by Zorbit View Post
    I can't help feeling that the thermal expansion of epoxy concrete, typically twice as much as steel, is going to tie that machine in knots. I'm happy to be educated otherwise.
    This was something I failed to find any kind of definitive answer to.
    The conclusion I drew, was it can't be that big a concern, given there are some very big EG machines with linear rails mounted to them, with no apparent allowance for expansion. So if it's not off any concern over a couple metres, I doubt I'd worry about it on your typical home build.
    As for John's build, what I took from his internal structure, was it was more about keeping things in place during the pour/cast, rather providing much in the way of structural support. Remember in that photo, the outer steel plates are the actual mold and designed to be removed after curing, so they can be reused.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #2
    Removed.
  4. The Following User Says Thank You to Zorbit For This Useful Post:
  1. BUILD LOG: Epoxy granite vertical mill build log
    By Nick in forum DIY Mill Build Logs
    Last Post: 08-06-2020, 06:30 AM
  2. Large Format Epoxy Granite Gantry CNC - Looking For Feedback
    By Max Maker in forum Gantry/Router Machines & Building
    Last Post: 23-08-2019, 04:57 PM
  3. BUILD LOG: DIY Epoxy composite gantry frame milling machine
    By John McNamara in forum DIY Mill Build Logs
    Last Post: 03-08-2019, 04:22 PM
  4. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  5. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
