The papers I read seemed to say that the major deciding factor was the % of mineral filler, and then the particle size distribution - you seem to need a fair % of small stuff to keep the minimum distance of epoxy small and fill in around any larger lumps. Some people were going as high as 90% mineral, albeit with a material which was little more than sand, hence would pack together tightly - the low % of epoxy would eliminate areas of overly-expanding undiluted epoxy I guess. Removing air bubbles is another issue - good luck with your build!
The Following User Says Thank You to Voicecoil For This Useful Post:
BUILD LOG: Epoxy granite vertical mill build log
By Nick in forum DIY Mill Build LogsReplies: 60Last Post: 08-06-2020, 06:30 AM -
Large Format Epoxy Granite Gantry CNC - Looking For Feedback
By Max Maker in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2019, 04:57 PM -
BUILD LOG: DIY Epoxy composite gantry frame milling machine
By John McNamara in forum DIY Mill Build LogsReplies: 28Last Post: 03-08-2019, 04:22 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM
