    Something like
Name:	Screenshot 2020-09-21 at 19.21.03.png
    All depends on your use-case. In this example UCCNC simply bypasses the manual switches to force the compressor on. Set the M8 command pin/port on setup/spindle page.
    You would still be able to turn on the compressor with the existing switches, but not turn off the compressor with the switches if enabled by the AXBB.
    That relay?, if it's the right coil voltage and current to suit the AXBB?
    EDIT: You could glam up the circuit but there's a certain KISS approach to the above.
    I had a play and came up with this Click image for larger version.
Name:	compresor with relay.JPG
    It does what your diagram does but also isolates the live from the 2 way switches when UCCNC has control.
  1. BUILD LOG: Quite an Unusual one
    By Boyan Silyavski in forum DIY Router Build Logs
    Last Post: 18-04-2023, 06:04 PM
  2. An unusual problem
    By racerbear02 in forum Machine Discussion
    Last Post: 10-01-2016, 11:45 AM
  3. Unusual Knife Block
    By Christian Knuell in forum Woodworking Project Showcase
    Last Post: 10-09-2014, 11:28 AM
  4. Which air compressor?
    By newtoid1986 in forum General Discussion
    Last Post: 12-12-2011, 04:07 PM
