24-09-2020 #19
It was actually an after thought to make it 100% automatic, if you have a 24V Normally Closed valve knocking around would you swap it for a Normally Open one? No problem if not as I will just wire it up so the NO valve closes when the compressor is powered on with the manual switches.
BUILD LOG: Quite an Unusual one
By Boyan Silyavski in forum DIY Router Build LogsReplies: 205Last Post: 18-04-2023, 06:04 PM -
An unusual problem
By racerbear02 in forum Machine DiscussionReplies: 5Last Post: 10-01-2016, 11:45 AM -
Unusual Knife Block
By Christian Knuell in forum Woodworking Project ShowcaseReplies: 1Last Post: 10-09-2014, 11:28 AM -
Which air compressor?
By newtoid1986 in forum General DiscussionReplies: 7Last Post: 12-12-2011, 04:07 PM
