Page 6 of 14 FirstFirst ... 45678 ... LastLast
  1. #51
    Hood's Avatar
    Lives in Carnoustie, United Kingdom. Last Activity: 28-10-2021 Has been a member for 3-4 years. Has a total post count of 28. Received thanks 1 times, giving thanks to others 0 times.
    A rotary would be my choice but just having a quick look they are quite steep in price nowadays. Years ago I had a 5hp static and fitted an idler motor to it and it worked great, nice clean (proper) 3 phase.
    I will ask around and see if anyone needs a spindle motor/drive that size but I think most of the people I know, like me, require 12kw or more.
  2. #52
    Chaz's Avatar
    Quote Originally Posted by Hood View Post
    Thanks, appreciated.
  3. #53
    Chaz's Avatar
    Double Post
  4. #54
    So SZGH are saying that this spindle setup wont work behind an invertor / filter. Of course, it might, but not surprised as without testing / knowing, they put their hardware and reliability at risk.
    So, anyone want to buy a 7.5KW 380 3 Phase Driver, Spindle Servo Motor, cables and braking resistor? The cost to me was $USD 990, plus a bit of tax and sadly the shipment was expensive due to the weight of the motor (60 ish KG). Let me know if interested. Ill possibly stick it up for sale on a few other places too.
    Surely it's only the drive you require not the motor.? this wouldn't cost a fortune to replace. What is the model number of the drive, so I can check it against mine which does supposedly work with single-phase, though I haven't tried it, and will use 3 phase anyway?
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  5. #55
    Chaz's Avatar
    Thanks.
    I thought so too, so queried with them, reckon no go as the motor is wired for 380V. I did notice when I connected it they only expose 3 wires, so cant change from high to low voltage.
    The drive is SZGH-S4T7P5, the motor is SZGH10-3-48-7.5/11-4-1500.
    Hood's Avatar
    Would you get a single phase drive for a motor that size?
    For servo drives 3Kw seems to be about the max for single phase and I would have thought spindle drives would be the same.
  7. #57
    Chaz's Avatar
    Good question. I hope so, otherwise Ill need to make a plan here.
    I run my 6.8 KW 24K HSD spindle on single phase with an inverter. Its a 380V version but I know you can specify 220V at that power.
  8. #58
    When I asked SZGH Mike told me the drive I have could be run on a single-phase supply but at a de-rated motor output.(approx 20%) Not that it matters because I will be running it on 3 phase anyway.
  9. #59
    Chaz's Avatar
    And that was my understanding too. What I did not pick up was that the version I ordered is 380V only. Ive had words with them, I intend to order more stuff - then they quoted on Friday for 220V 3 Phase despite me reminding them I only have single phase.
    They suggested they could supply one of the items at cost as a 'sorry' for the issue but then tell me how much more complicated / expensive the 220V version is, so perhaps no discount after all. Lets see, Ill probably hear from Susie in the morning.
  10. #60
    You may be lucky, i sent an email to Mike and received this reply:
    Sorry for late replay because we are on Holiday this term as Chinese New Year(6th,February,2021-18th,February,2021).Happy Chinese New Year to you and your family!!! We will feedback to you soon after holiday! Thank you very much for your understand!
    Then later he replied, work that one out.
  1. FOR SALE: Hardinge HLV-H lathe for sale
    By bkiene in forum Items For Sale
    Last Post: 02-06-2022, 04:43 PM
  2. Emco 120 cnc lathe retrofit
    By Toolman321 in forum Emco Lathes
    Last Post: 08-05-2022, 05:04 PM
  3. Replies: 3
    Last Post: 29-08-2020, 04:35 PM
  4. Hardinge lathe Retrofitting project
    By Gary in forum Classified Ads, Buy, Sell & Swap
    Last Post: 19-06-2020, 06:14 PM
  5. NEW MEMBER: Hardinge HLV-H Lathe
    By Roger Williams in forum New Member Introductions
    Last Post: 25-08-2009, 01:56 PM
