25-12-2020 #10
I haven't had this issue but I'm using Absolute encoders and I think you and Chaz are using Incremental which might make a difference as the position is saved in memory and talks to the controller first so doesn't rely on the motors encoder to report back, however, every so often I do get one drive fault on start-up. Can be any of the drives, it's random, reset and it's fine never does it again no matter how many times you switch on/off.!! . . .It's a strange one.?
This is just on the bench still has I haven't had time to fit on the machine and It's probably because it's rough arse wired on the bench and running through a multiplug extension cable on a 13A plug with no Inrush or line filters but I'll be contacting SZGH before fitting to check but thought I'd mention it just in case anyone else is having similar issues.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
FOR SALE: Hardinge HLV-H lathe for sale
By bkiene in forum Items For SaleReplies: 0Last Post: 02-06-2022, 04:43 PM -
Emco 120 cnc lathe retrofit
By Toolman321 in forum Emco LathesReplies: 3Last Post: 08-05-2022, 05:04 PM -
FOR SALE: Hardinge HLV super precision Lathe | CNC conversion bits Mesa | Leadshine | C5 screws
By Jools in forum Items For SaleReplies: 3Last Post: 29-08-2020, 04:35 PM -
Hardinge lathe Retrofitting project
By Gary in forum Classified Ads, Buy, Sell & SwapReplies: 1Last Post: 19-06-2020, 06:14 PM -
NEW MEMBER: Hardinge HLV-H Lathe
By Roger Williams in forum New Member IntroductionsReplies: 1Last Post: 25-08-2009, 01:56 PM
