Threaded View
28-09-2020 #1
Hello,
I have run a router for a few year, home built (1000mm x 800mm x 150mm) using Mach3 on an old XP machine. The BOB (break out board) was from CNC4YOU, the HG08. It has for the best part been...ok... a few XP/MACH3 crashes and the odd un explained error or excursion! The other machine I have is a Warco GH Universal that again uses the same XP machine but the CPO10V BOB again from CNC4YOU. This mill has a 3 phase motor running through the original Warco GH gearbox, so spindle speed tops out around 3200rpm but I can change gear to give torque when needed. I also have made my own Tormach style tool holders which certainly speed tool changes up but the 20mm R8 collet can't be relied on for roughing with bigger cutters.
I have been getting more and more frustrated with MACH3 interface and stability. Not really sure where the in-stability is coming from but the most common error I get is that the USB keyboard stops working or acts as if a key is permanently held down. Sometimes unplugging the keyboard and plugging back in sorts it, other times its a MACH3 restart or PC restart. I am finding jogging around with the keyboard a pain, I have a XHC pendant but it works little better than the keyboard and knowing which direction its going to travel always catches me (maybe I should practice more!)
For workflow I use SolidWorks in my job and use Fusion to create toolpaths. Don't know about anybody else but the sketcher in Fusion is hard work!
So I am on the hunt for a better motion control solution. This is probably going to create a load of groans and one mans great controller is another mans nightmare! I think I would prefer a non PC based solution but could be convinced otherwise.
So far I ve had a little look at
UC400ETH Ethernet (UCCNC)
AXBB-E ethernet
DDCS 3.1 Controller
Masso 3 axis (Favorite so far)
and disregarded
Machifit SMC5-5-N-N
NVEM 5 Axis CNC Controller Ethernet
WiXHC USB Mk3
So any advice either long or short reply would be appreciated.
Simon
WANTED: Motion Controller
By petesurrey in forum Items WantedReplies: 1Last Post: 30-12-2017, 01:13 AM -
What is the advantage of using a motion controller rather than just a PC and BOB?
By Agathon in forum Control Hardware & SystemsReplies: 10Last Post: 11-08-2017, 04:34 PM -
Uc300 motion controller problems
By Hellfire in forum CNCdrive (UCCNC)Replies: 2Last Post: 07-11-2016, 07:21 PM -
Advice please! JAF Motion Controller issues!
By Mark Chard in forum Machine Control SoftwareReplies: 0Last Post: 31-01-2014, 05:03 PM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM
