Page 5 of 14 FirstFirst ... 34567 ... LastLast
  1. #41
    hi andre
    thanks for the explanation now i understand:naughty:
    you should write a book on this for any others out there considering doing the same job:heehee::heehee:
    keep up the great work
    Tom
  2. #42
    Great pic's Andre? Following your project with special intrests, soon no more good beavers to find on the second hand market anymore .... ;-)
  3. #43
    Here we are again,
    Last week has been busy and have not don as much as I wanted.
    But now I've made the design for the Z axis bearing configuration.
    As you can see on the drawing .
    So tomorrow I can start the making of the parts.:dance:
    Attached Thumbnails Attached Thumbnails z-spindel-as.pdf
  4. #44
    How are you going to limit backlash in the bevel gears or is this just an adjustment drive?
    Peter
  5. #45
    Hello Peter,
    On one side there will be the timing pulley and the other side is the ballscrew.
    The bevel gears I have are helical bevel gears (the original BEAVER) and I will adjust them with spacers so that slack will be no more.
    Kind regards .
    Andre
  6. #46
    Hello everyone,
    Here are a series of pictures of how a component from the Z axis is machined.
    This part is made of steel and it is one of the more complex parts I need.
    The series pics are self explanatory.
    And in the right order.
ID:	1514   Click image for larger version.
ID:	1521   Click image for larger version.
ID:	1522   Click image for larger version.
  7. #47
    More photo's
ID:	1515   Click image for larger version.
ID:	1516   Click image for larger version.
ID:	1517   Click image for larger version.
ID:	1518   Click image for larger version.
ID:	1519   Click image for larger version.
  8. #48
    Tip drawing the outline on the workpiece itself so you can see what ultimately the part will be.
    Also as much material will be removed make sure that there is material left
    to machine after the biggest piece is removed because the workpiece will deform by tensions in the material.
ID:	1528   Click image for larger version.
ID:	1534   Click image for larger version.
ID:	1535   Click image for larger version.
ID:	1536   Click image for larger version.
ID:	1537   Click image for larger version.
ID:	1538   Click image for larger version.
ID:	1539   Click image for larger version.
ID:	1540   Click image for larger version.
ID:	1541   Click image for larger version.
  9. #49
    For the rounds I use a rotary table (my machine table is a rotary table ass well)
ID:	1547   Click image for larger version.
ID:	1553   Click image for larger version.
ID:	1554   Click image for larger version.
ID:	1555   Click image for larger version.
ID:	1556   Click image for larger version.
ID:	1557   Click image for larger version.
ID:	1558   Click image for larger version.
ID:	1559   Click image for larger version.
ID:	1560   Click image for larger version.
  10. #50
    Tip use a rough mill where possible.
    An for finishing I use an endmill.
ID:	1563   Click image for larger version.
ID:	1571   Click image for larger version.
ID:	1572   Click image for larger version.
ID:	1573   Click image for larger version.
ID:	1574   Click image for larger version.
ID:	1575   Click image for larger version.
ID:	1576   Click image for larger version.
ID:	1577   Click image for larger version.
ID:	1578   Click image for larger version.
  1. CONVERSION: Archdale Conversion
    By meyerga00 in forum Conversion Build Logs
    Last Post: 17-06-2012, 09:24 AM
  2. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  3. Bridgeport Conversion
  4. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
  5. A little conversion tool
    By D-man in forum Computer Software
    Last Post: 18-12-2010, 04:58 PM
