Page 7 of 14 FirstFirst ... 56789 ... LastLast
  1. #61
    That looks good Tom now you can start your own build log if you rebuild this one.
    Ps: The next set pictures from my beavermill will come soon.
    Kind regards,
    Andre
  2. #62
    Cant wait !
    .Me
  3. #63
    Hello here we are again.
    After a number of other urgent matters I had to make do, I can focus my attention back to the beaver mill.
    The first thing I did was the existing ball crew adjusted to the new situation,
    Starting with the removal of the hardened layer on the lathe.
ID:	1973   Click image for larger version.
ID:	1974   Click image for larger version.
ID:	1975   Click image for larger version.
ID:	1976   Click image for larger version.
ID:	1977   Click image for larger version.
ID:	1978   Click image for larger version.
  4. #64
    After removing the hard layer I put on a steady rest (A support that is clamped to the bed of a lathe,
    used when machining a long workpiece. Sometimes
    called a center rest.).
    And then I flipped the piece and cut the rest matriaal
    off.
    But first I have the chuck jaws to suit the ball screw,I have a number of different sizes of washers to put between the jaws to support them during turning .I turn them to the right dimension in this case 40 mm so I will not damage the part. After cutting off the exes material I make a new center whit a center drill.
ID:	1987   Click image for larger version.
ID:	1988   Click image for larger version.
ID:	1989   Click image for larger version.
ID:	1990   Click image for larger version.
ID:	1991   Click image for larger version.
ID:	1992   Click image for larger version.
  5. #65
    Then I removed the steady rest and the finished part and Put On Some tread for the nut and make a groove for a circlips I am using a caliper to measure the tread
ID:	1994   Click image for larger version.
ID:	1995   Click image for larger version.
ID:	1996   Click image for larger version.
ID:	1997   Click image for larger version.
ID:	1998   Click image for larger version.
ID:	1999   Click image for larger version.
ID:	2000   Click image for larger version.
ID:	2001   Click image for larger version.
ID:	2002   Click image for larger version.
  6. #66
    Next thing we did is making the key way and two flat sides ,
    I always measuring key ways rectangular pockets with precise gauge blocks
ID:	2005   Click image for larger version.
ID:	2006   Click image for larger version.
ID:	2007   Click image for larger version.
ID:	2008   Click image for larger version.
ID:	2009   Click image for larger version.
ID:	2010   Click image for larger version.
ID:	2011   Click image for larger version.
  7. #67
    Now we make the nut.
    As you can see, you can use a ball bearing for centering the workpiece.
ID:	2013   Click image for larger version.
ID:	2014   Click image for larger version.
ID:	2015   Click image for larger version.
ID:	2016   Click image for larger version.
ID:	2017   Click image for larger version.
ID:	2018   Click image for larger version.
ID:	2019   Click image for larger version.
ID:	2020   Click image for larger version.
ID:	2021   Click image for larger version.
  8. #68
    After turning we are going to mill.
ID:	2023   Click image for larger version.
ID:	2024   Click image for larger version.
ID:	2025   Click image for larger version.
ID:	2026   Click image for larger version.
ID:	2027   Click image for larger version.
ID:	2028   Click image for larger version.
ID:	2029   Click image for larger version.
ID:	2030   Click image for larger version.
  9. #69
    Later on we have made several small parts but we do not have pictures of everything because they are simple parts to make.
ID:	2032   Click image for larger version.
ID:	2033   Click image for larger version.
ID:	2034   Click image for larger version.
ID:	2035   Click image for larger version.
ID:	2036   Click image for larger version.
ID:	2037   Click image for larger version.
ID:	2038   Click image for larger version.
ID:	2039   Click image for larger version.
ID:	2040   Click image for larger version.
ID:	2042   Click image for larger version.
  10. #70
    We have adjusted the part of the base to the ball screw so they can be mounted together.
ID:	2044   Click image for larger version.
  1. CONVERSION: Archdale Conversion
    By meyerga00 in forum Conversion Build Logs
    Last Post: 17-06-2012, 09:24 AM
  2. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  3. Bridgeport Conversion
  4. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
  5. A little conversion tool
    By D-man in forum Computer Software
    Last Post: 18-12-2010, 04:58 PM
