    Hi all,
    Been thinking on making a fixture plate with threads and holes for dowel pins for the router.
    Would love to use 6mm dowel pins for aligning/fixture and wondering if this con be done by the router itself. I´ve got a 2.2Kw spindle, would a 5.9mm drill and a caribe reamer like this suit the process? How would you go about making this?
    Thanks in advance,
    Jordi
    Quote Originally Posted by jordiboronat View Post
    Hi all,
    Thanks in advance,
    Jordi
    I would have thought the RPM too fast for a reamer.. Could you not drill therough both pieces in situ and hand ream?
    Ideally I would like to have an array of threads and holes hence the plan to use the cnc.
    Boosting the torque on the VDF I´m able to drill given I stick to small diameters. My thoughts are that maybe by using a short carbide reamer this can be done on a chinese spindle, but would be great to hear if someone has done it already.
    Anyone has experience on this?
    In that case drill a series of holes in piece of scrap then machine each one a slightly larger diameter (4.000, 4.001, 4.002) with a 4mm end mill. Then see which hole has the best fit with the pin and machine your plate that diamater.
  1. NEW MEMBER: About to fall down the rabbit hole ??
    By Ollie78 in forum New Member Introductions
    Last Post: 21-03-2019, 08:18 PM
  2. Newbie help hole boring
    By dfox1787 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 14-05-2018, 09:47 AM
  3. can someone please help with hole dimensions
    By reefy86 in forum Solidworks
    Last Post: 20-02-2016, 12:44 PM
  4. Reaming question
    By jimbo_cnc in forum Metalwork Discussion
    Last Post: 25-10-2014, 10:21 PM
  5. Hole Radius
    By benkat in forum Machine Discussion
    Last Post: 03-03-2014, 05:29 PM
