I can't see why you have to re-upload the Arduino code to your Boxzy, since it was just the laptop software that went kaput? You ought to be able to just install the software on the laptop and start talking to what is already loaded in the Arduino. In other words, follow their installation procedure but skip any steps about uploading firmware to the Boxzy since that's already there.
You will have to install the Arduino software just to get the drivers, but that's probably all you'll need to do on that part. The PC software is the main thing you need to re-instate since that is your interface to what is on the Arduino in the machine.Last edited by Adrian_S; 02-10-2020 at 09:39 PM.
The Following User Says Thank You to Adrian_S For This Useful Post:
NEW MEMBER: Programmer 3 axis milling machine from vietnamese
By cncmachineokk in forum New Member IntroductionsReplies: 1Last Post: 03-08-2017, 05:51 AM -
WANTED: 3-4 AXIS CNC Milling machine wanted
By markhuk in forum Items WantedReplies: 0Last Post: 15-10-2015, 02:10 AM -
Buying a 3 axis cnc milling machine
By valegraphics in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 12-10-2014, 03:49 PM -
DIY arduino CNC 2 axis table
By ruthharm84 in forum Electronic Project BuildingReplies: 5Last Post: 06-05-2012, 01:54 AM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
