**** NO EXPERIENCE HERE ****
(Agree with Adrian_S - the firmware running on the Arduino doesn't/shouldn't need reloading - that's a one-off configuration thing; re. drivers?, possibly - though that's just the serial driver which you may have already installed on your laptop).
I suspect what you have is an engraving machine with an Arduino running an instance of the open-source GRBL software. The Boxzy software would be the g-code streamer/manual control software to the Arduino.
If you're in a hole, I'd look at similar modern machines - they're all likely running similar g-code streamers and manual control software. You may need to reallocate I/O to match the pin mapping on your machine (or rewire) - that's can be "fun" for a while then it'd become tedious - if you're very lucky then many machines will have the same default mapping. But if you can't get the recent PC software to talk to the Arduino and you're really in a corner, there's very little to stop you flashing a new Arduino build for a recent machine, and using the up-to-date PC software. As above, the biggest challenge will be ensuring the I/O mapping is correct.
The Following User Says Thank You to Doddy For This Useful Post:
NEW MEMBER: Programmer 3 axis milling machine from vietnamese
By cncmachineokk in forum New Member IntroductionsReplies: 1Last Post: 03-08-2017, 05:51 AM -
WANTED: 3-4 AXIS CNC Milling machine wanted
By markhuk in forum Items WantedReplies: 0Last Post: 15-10-2015, 02:10 AM -
Buying a 3 axis cnc milling machine
By valegraphics in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 12-10-2014, 03:49 PM -
DIY arduino CNC 2 axis table
By ruthharm84 in forum Electronic Project BuildingReplies: 5Last Post: 06-05-2012, 01:54 AM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
