I'm guessing the Boxzy software is using some of the Arduino libraries, which is why it needs the Arduino software to be installed first.
As Doddy has mentioned, I'd guess they're also using GRBL with some kind of customised computer software to control it. Although there is the possibility they've used some of the CNC code aimed at 3D printers. Regardless, if you know the pin connections used, it should be possible to get GRBL to work.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
NEW MEMBER: Programmer 3 axis milling machine from vietnamese
By cncmachineokk in forum New Member IntroductionsReplies: 1Last Post: 03-08-2017, 05:51 AM -
WANTED: 3-4 AXIS CNC Milling machine wanted
By markhuk in forum Items WantedReplies: 0Last Post: 15-10-2015, 02:10 AM -
Buying a 3 axis cnc milling machine
By valegraphics in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 12-10-2014, 03:49 PM -
DIY arduino CNC 2 axis table
By ruthharm84 in forum Electronic Project BuildingReplies: 5Last Post: 06-05-2012, 01:54 AM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
