Thread: Boxford TCL125. (Fresh start )
I was watching you orignal thread with interest.
I've jsut come out of the other end of a Boxford VMC190 conversion to Linuxcnc
I would be interested in the pair of boards that have the drivers on them, two or three block things about 2" x 3"
You will be using more modern drivers I assume.
I kept the Lenze speed controller, but my isolation board on the end of the lenze was toast, so I had to wire the lenze into the control board. This is not that straigth forward as the lenze 0v to 10v (for spinlde speed control) floats at 110v to 122v
I found a step/dir to 0v to 10v board with on/off relay and its all working a treat now
I converted an ORAC Lathe to LinuxCNC about a year ago and its been great, It threads a treat which was something I could never get my boxford BUD running Mach3 do. IT all done on the cheap with a PC mother board parallel port and an additional port card
The VMC is also using a single parallel port card that provides two parallel port connections
In LinuxCNC set the first one up as OUT and the second as IN and you have more than enough inputs.
Both machines have a control panel with real buttons
Cheers,
Paul
14-10-2020 #2
Hi Paul
I had thought that the isolation cad on the lenze controller gave that protection.
If you look at the wiring diagram I inserted earlier in this thread , the 0v connection from the iso board ( term 5) come back to a common 0v buss which picks up the the drivers and rectifiers on its way back to a direct connection to the Mains Earth.
I will be using the Bob which was repaired for me by Doddy which has the facility for a 0-10v signal but only a make/break relay.
Does the DIYCNC spindle board generate its own signal output, so no need to connect the BOB 0-10 signal ? Or might it be better to take the speed regulation signal straight from the BOB and cut out the middle man as it were?
FOR SALE: Boxford TCL125 ATC
By jonnydeen in forum Items For SaleReplies: 4Last Post: 27-11-2021, 12:41 AM -
FOR SALE: Boxford MT2 & Boxford TCL125
By jonnydeen in forum Items For SaleReplies: 3Last Post: 12-11-2021, 11:24 AM -
WANTED: Automatic Tool Changer for Boxford TCL125
By TomHennessy in forum Items WantedReplies: 14Last Post: 31-10-2020, 10:25 AM -
By 30tooo in forum Items For SaleReplies: 17Last Post: 28-06-2017, 04:29 PM -
BUILD LOG: fresh start 8x4 build
By reefy86 in forum DIY Router Build LogsReplies: 31Last Post: 02-01-2017, 12:45 PM
