Thread: Boxford TCL125. (Fresh start )
07-11-2020 #41
Hi again folks
Have replaced the opto switches but i am struggling to follow the calcs above
Taking figures from page 5 of the datasheet Forward voltage is 1.7 v max with a forward current of 20mA, so with two lamps in series we have a forward voltage of 3.4.
Not sure how I choose the forward current but 20mA is the figure given in the conditions column so will go with that.
So cautiously driving with a 5 v supply 5- (2x1.7) = 1.6V and at 20 mA I calculate a resistor of 80 ohms and I dont have one.
And I still cant quite understand why Boxford were driving the same rig with a 10v output and no apparent resistor , so with tongue firmly in the cheek and having a couple of spare opto switches my inexperienced mind thinks why not give it a shot without resistor anyway.
So I wired to plus 5 v and brought the single pulse (blue wire) back to pin 12 , set this up in Mach 3 I am not understanding the other settings I see in Mach.
I get figures flashing up for true spindle speed as I switch on with say S500 but these figures die away to zero as spindle runs up.
I am bewilderd by the range of settings I may need to address so if any one can guide me I would appreciate.
I presume that spindle pulleys just selects a speed range so I think I am OK with that
But Ports and pins , spindle setup , spindle motor , motor outputs , PID settings have lost me, even before I get into Encoder settings
07-11-2020 #42
20mA is usually around the max rated forward current. It's a fairly conventional rule of thumb to select 10mA. That'd give a resistor of 160R, or thereabouts (selecting 10mA as the basis of the resistor calculation gives you a lot of wiggle - you can halve it and still be within the working limits, chances are you could double it and it'd still work). You get less flexibility as you chose a resistor for a larger forward current, of course.
An idealised, simplified model of an LED would presented a voltage source of V-forward (1.7, above), and 2 in series would be 3.4V. That then would mean without a series resistor you're presenting 1.6V (as you say) into a dead short - theoretically infinite current and the blue smoke escapes. Of course, the real model of the LED would have some internal series resistance, and there's the series resistance of the cabling, and the PSU. It might work. It might work for a while. It might work for not very long. But you have spares!, and if you want any resistors thrown in the post I can do that. It's an interesting experiment in any case, and you can but learn from it.
With Mach, can you confirm that with stationary spindle you get 0 RPM. Then at very low RPM you get some RPM (maybe not the right RPM, but some). The first thing you want to make sure is that the encoder input is working before getting too hooked into the inner workings. You should be able to monitor P12 input on diagnostics page and rotate the spindle by hand to find the index position - just confirm that is working with 1 PPR.
07-11-2020 #43
Would appreciate a couple of resistors suitable for the task Doddy. You still have my address I presume.
And yes spindle speed shows as zero
07-11-2020 #44
Not seeing any illumination on pin 12 as I rotate the disc past the single slot
07-11-2020 #45
07-11-2020 #46
Are there optical switches with a better voltage tolerance ?
07-11-2020 #47
That's the purpose of the resistor.
EDIT: I'll get a selection in the post on Monday morning.
07-11-2020 #48
Am currently trying to set up a profile in Linux cnc .
Would that be an easier to place to start .
08-11-2020 #49
RS Components do free delivery on all online orders which makes it economical to order only a few LEDs, resistors etc. of various values costing next to nothing for experimenting. I used to feel guilty about this and try to wait until I had a larger order, but they end up sending your order in 5 envelopes from 3 different countries anyway so don't worry about it. RS are not always the cheapest supplier but for small orders the free postage is very useful and delivery (here in Australia anyway) is quick.
If you're not sure what you need I'm sure there are several readers who could scan the online catalogue and suggest RS part numbers for you even if we don't have components we can send you directly.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
08-11-2020 #50
(Deleted - retreats with egg on face due to not being able to count on fingers and get same answer twice)
FOR SALE: Boxford TCL125 ATC
By jonnydeen in forum Items For SaleReplies: 4Last Post: 27-11-2021, 12:41 AM -
FOR SALE: Boxford MT2 & Boxford TCL125
By jonnydeen in forum Items For SaleReplies: 3Last Post: 12-11-2021, 11:24 AM -
WANTED: Automatic Tool Changer for Boxford TCL125
By TomHennessy in forum Items WantedReplies: 14Last Post: 31-10-2020, 10:25 AM -
By 30tooo in forum Items For SaleReplies: 17Last Post: 28-06-2017, 04:29 PM -
BUILD LOG: fresh start 8x4 build
By reefy86 in forum DIY Router Build LogsReplies: 31Last Post: 02-01-2017, 12:45 PM
