    inee's Avatar
    Lives in bris, United Kingdom. Last Activity: 19-09-2022 Has been a member for 5-6 years. Has a total post count of 21. Received thanks 1 times, giving thanks to others 0 times.
    Hi john.
    the colour codes for the wires is in the manual, the index is a single slot on the disc, the timing has a lot more. If the index doesn't trigger correctly you need to widen the slot a tad
    Am playing at the moment in Mach 3 but fully intend to convert to Linux when I get everything working!
    I have the encoder cable but just unsure how to connect it . I dont have a pinout for this Bob. (They dont do instructions for this price )
    https://www.ebay.co.uk/itm/Mach3-CNC...0AAOSw6Olffu9N
    I got to the pin settings for the 0-10v output by trial and error with motor set for step /direction control rather than PWM. It works but I may not have it right and I am struggling to understand how a step /direction signal controls a relay or a voltage output , so I am apprehensive about connecting an encoder without understanding what I am doing and why I am doing it .
    Is there any clear guidance or manual for this task.
    Prior to this my only experience was the mill function. I can handle the idea that inputs to pins 2 and 3 provide step and direction instructions to a stepper driver for X motion.
    Y and Z similarly. and the CNC4 you board had specific instructions for spindle "on " control. I never got around to varying the spindle speed .
    Choosing the pin settings to make X Y and Z movements happen seems intuitive enough .
    and spindle relay on is not too hard to grasp in Mach. But pwm and encoder settings are at the moment testing my intellect a bit
    I have looked for pin settings for this board but cant find specific ones online .
    Which Manual are you referring to Inee? Cant see anythingin the Boxford or Lenze manuals and I dont think I have one specifically for the encoder.
    Will explore a bit more .
    If someone can hold my hand here and tell me which pin settings to select to get me going , I suspect that things will begin to fall into place and from there I can maybe ask the relevant questions to give me an understanding of what settings I have made .
    inee's Avatar
    Hi john the boxford manual (will link in a tick
    Below is the manual should be for your bob,
    MACH3-BL-MACH-V1.1.pdf
  1. FOR SALE: Boxford TCL125 ATC
    By jonnydeen in forum Items For Sale
    Last Post: 27-11-2021, 12:41 AM
  2. FOR SALE: Boxford MT2 & Boxford TCL125
    Last Post: 12-11-2021, 11:24 AM
  3. WANTED: Automatic Tool Changer for Boxford TCL125
    By TomHennessy in forum Items Wanted
    Last Post: 31-10-2020, 10:25 AM
  4. FOR SALE: Boxford TCL125
    By 30tooo in forum Items For Sale
    Last Post: 28-06-2017, 04:29 PM
  5. BUILD LOG: fresh start 8x4 build
    By reefy86 in forum DIY Router Build Logs
    Last Post: 02-01-2017, 12:45 PM
