Thread: My knowledge = Zero :-D
09-10-2020 #2
It's not a problem given that I have a reasonably fast broadband connection - just that compared to F360 which I seem to remember is around 75MB, it seems enormous. That can't be right for F360, looking at the numbers, but I still don't believe it's quite that big!
A friend of mine is working on a fairly complex 3D model of a twin-bank radial aero engine and has switched to Solidedge from F360 as he reckons it's quite a bit more powerful. Not sure which version he's using, though.
09-10-2020 #3
I thought F360 was semi-browser based, not sure....?
09-10-2020 #4
Onshape is browser-based; F360 runs locally. I think! Autodesk have apparently been working on a browser-based version of F360 but I don't think it's ready for prime-time yet. Every time F360 updates (every few weeks or so), there's a fairly big download in the background but not as big as SE.
09-10-2020 #5
12-10-2020 #6
ok I'm a bit confused.. I downloaded and installed solid edge 2020 but it seems a bit in depth for me especially as I only need to learn 2d for now. I then downloaded Solid Edge 2D but when I try to install it it just tries to modify or repair Solid Edge 2020. Its definitely a different download as its a different size. Do I need to uninstall Solid Edge 2020 to install the 2D version?
12-10-2020 #7
Yes you need to uninstall the 3d version before installing the 2d. For some reason only one version of solid edge is allowed on one system, even previous releases.
12-10-2020 #8
Thank you!
NEW MEMBER: Hello, im new here :) looking for knowledge machining with high speed spindles
By donfrondo in forum New Member IntroductionsReplies: 4Last Post: 08-07-2019, 01:09 PM -
Where is the fountain of knowledge for learning about CNC setups / understanding them
By Palletlad in forum Chinese MachinesReplies: 62Last Post: 15-02-2018, 08:23 PM -
Fill in my knowledge gap :)
By Davek0974 in forum CamBamReplies: 50Last Post: 02-02-2017, 02:55 PM
