Page 2 of 2 FirstFirst 12
    Just downloaded it - all 3.5GB of it for the 3D version! - and installing to give it a try. Thanks for the pointer.
    No problem, it's a large download because the full program is contained within, additional features are locked.
    Lives in Plymouth, United Kingdom. Last Activity: 6 Hours Ago Has a total post count of 1,746. Received thanks 297 times, giving thanks to others 11 times.
    It's not a problem given that I have a reasonably fast broadband connection - just that compared to F360 which I seem to remember is around 75MB, it seems enormous. That can't be right for F360, looking at the numbers, but I still don't believe it's quite that big!
    A friend of mine is working on a fairly complex 3D model of a twin-bank radial aero engine and has switched to Solidedge from F360 as he reckons it's quite a bit more powerful. Not sure which version he's using, though.
    I thought F360 was semi-browser based, not sure....?
    Onshape is browser-based; F360 runs locally. I think! Autodesk have apparently been working on a browser-based version of F360 but I don't think it's ready for prime-time yet. Every time F360 updates (every few weeks or so), there's a fairly big download in the background but not as big as SE.
  5. #15
    That's the difference between Awfuldesk and Siemens, fortnightly updates are mostly for bugs and instability. Siemens have updates probably every six months, in fact I can't remember the last update, just a reliable and stable tool.
  6. #16
    ok I'm a bit confused.. I downloaded and installed solid edge 2020 but it seems a bit in depth for me especially as I only need to learn 2d for now. I then downloaded Solid Edge 2D but when I try to install it it just tries to modify or repair Solid Edge 2020. Its definitely a different download as its a different size. Do I need to uninstall Solid Edge 2020 to install the 2D version?
  7. #17
    Yes you need to uninstall the 3d version before installing the 2d. For some reason only one version of solid edge is allowed on one system, even previous releases.
  8. #18
    Thank you!
  1. NEW MEMBER: Hello, im new here :) looking for knowledge machining with high speed spindles
    By donfrondo in forum New Member Introductions
    Last Post: 08-07-2019, 01:09 PM
  2. Replies: 62
    Last Post: 15-02-2018, 08:23 PM
  3. Fill in my knowledge gap :)
    By Davek0974 in forum CamBam
    Last Post: 02-02-2017, 02:55 PM
