Thread: Boxford v190 cnc
I could not agree more Doddy
Every time I think I understand linuxcnc configuration I realise that I don’t
But I am getting there and the linuxcnc forum is excellent
The stepconfig wizard gets you the basic machine up and running then you built it up from there. I’ve eaten more than one packet of chocolate hobnobs
Don’t forget the parport configuration that I posted yesterday this tool me all evening to work out that the parport must be disabled in the bios This allows it to be seen along with a pci parport by Linux
This makes no sense to me but it worked on both versions of Linux and on linuxcnc 2.7.14. 2.7.15. 2.8. 2.9
Paul
The Following User Says Thank You to depronman For This Useful Post:
16-10-2020 #2
Hi John
I would be happy to burn you a dvd with the mint Linux and linuxcnc 2.8.0
I have used this very dvd today to set the HP of that arrives this week
Instal could not be simpler. Power on the pc. Open the dvd tray and pop in the dvd disk
Power off and then back on and press f9 and f10 repeatedly
You will get a boot selection screen. Select disk and wait a few seconds
Mint will start to boot up from the dvd
Once into the mint desktop there is disk icon on the desktop that you click to install mint and linuxcnc onto the desktop
Cheers. Paul
16-10-2020 #3
16-10-2020 #4
It works perfectly Bernie, just doesn’t like booting from a pen drive
Give it a dvd with the iso on it and it was as happy as Larry
It just took me some time to find my box of blank DVD’s. The mrs had put them somewhere safe
I guess bootable pen drives were not a thing in 2009
I still can’t get over how quiet the HP PC is you can hear a pin drop when it’s on
Cheers. Paul
16-10-2020 #5
Yes the pen drive is bootable. It’s been used to boot into Linux on numerous different PC’s laptops and even a MacBook Pro
I also entered the PC’s boot menu just after the bios
When I burned an dvd with the iso the pc booted up find using the dvd
Paul
16-10-2020 #6
Hi folks and thanks for the flurry of constructive help.
I have managed to make a boot drive , installed linuxmint as an OEM install wiping all other stuff on the way, and am accessing this forum via LM.
Will clearly get used to it and when I do I will download linux CNC.
May need a socially distanced gathering to set up CNC but could just about manage that with someone sitting on top the Bantam, the washing machine (for overalls ) would be a comfortable perch in the other corner , and if someone doesnt mind sitting on the Khasi then we could just about manage ,
Hobnobs or pasties depending on preference , and tea for man and beast.
Who would need a Forum??
All I need now is to get this "Effing" TCL 125 into running order and I think I am getting close .
Maybe still need some help on the spindle relay to get there
Did you do it from the link I gave you.I have managed to make a boot drive , installed linuxmint as an OEM install wiping all other stuff on the way, and am accessing this forum via LM.
If so you also have linuxcnc.
You mean like this:-I must admit that I get mightily perplexed by the jargon these software folks speak .and am accessing this forum via LM...Clive
16-10-2020 #8
Might need a LinuxCNC expert here - can LinuxCNC and the real-time kernel be easily installed on a Mint base installation? (I've only ever installed the LinuxCNC/Debian prebuilt package?
Reason I ask, John, is if not you may need to install the LinuxCNC ISO image similar to what Clive links to, in which case I wouldn't go too far down the path you're following, if you find yourself re-installing down the line
The link I put up is https://forum.linuxcnc.org/9-install...int-iso#165631 the RT version with Mint with linuxcnc and wifi support and is simple to upgrade .
In a terminal type
sudo apt-get update
then
sudo apt-get dist-upgrade
will get you the latest packages
If you want the official version :- http://www.linuxcnc.org/iso/linuxcnc-2.8.0-buster.iso The Debian 10 Buster ISO uses a PREEMPT-RT patch
But in my opinion the mint one is a lot more user friendly.Last edited by Clive S; 16-10-2020 at 11:02 PM.
16-10-2020 #10
My understanding is Doddy is correct
Linuxcnc needs the RT kernel
The link provided is for an iso of Linux mint 19.3 which also includes linuxcnc 2.8.0 already installed
This means that someone (beagle brain from memory) as already done the hard work and integrated linuxcnc into Linux mint
If I was John I would take the easy route abs use the iso with all of the hard work already done for you
Paul
FOR SALE: Boxford MT2 & Boxford TCL125
By jonnydeen in forum Items For SaleReplies: 3Last Post: 12-11-2021, 11:24 AM -
New Spindle drive Boxford V190 VMC
By mosoeng in forum Boxford Vertical MillsReplies: 4Last Post: 19-09-2019, 09:11 AM -
SOLD: Boxford 260 VMC
By Woodfish in forum Items For SaleReplies: 6Last Post: 11-12-2018, 08:34 PM -
FOR SALE: Boxford 160tcl Lathe and 260 vmc milling machine with full boxford software for sale
By Waine in forum Items For SaleReplies: 2Last Post: 21-04-2016, 09:18 AM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM
