Page 6 of 9 FirstFirst ... 45678 ... LastLast
    Will have a look again in the light of day .
    In all honesty Clive I got so lost amongst what google threw up that I "muddled "my way through, but no harm done as I can easily go back to square one and start afresh. With a clean box little is lost.
    At least I now know that Bernies box works ( Thanks again Bernie) and I now know how to make a bootable drive , So at least one step forward when I go your route Clive .
    I quite like the clean desktop of linux so will try to keep it that way and leave all the rubbish on the windows machine.
    I still have Mach3 and UCCNC on there for the mill , so maybe have to get used to switching. between operating systems
    Quote Originally Posted by John11668 View Post
    John
    Its no use to try and download linux from anywhere but from the linuxcnc site that is where the links came from that I gave you.
    The site that you linked to is charging you £9 for a 32 bit version of linux which is FREE . You need the 64 bit version from the linuxcnc site as it need a real time kernel.
    Please re read this post from the beginning. It is not as complicated as you make out. I will even post you a usb stick with linuxcnc on it and it will load linuxcnc in 10mins
    Sorry to be pedantic but these days linuxcnc has never been easier to load.
    John
    Sorry to hijack the thread - Clive - I'm keen to try Mint - do you know if it's possible/easy to install alongside another (Debian) install?, I really don't want to trash my Deb. install just yet, but I do prefer Ubuntu to Debian, and I guess Mint will provide a closer experience to Ubuntu.
    EDIT: And, apologies Clive - the link you pointed to (I'm there now to download your recommended ISO) also includes the instructions how to update a base Mint install to include the RT kernel, LinuxCNC etc, although I do think a clean install from an ISO provides the lowest risk hassle-free install.
    IF I am not mistaken you can boot the iso and it will load a live version to see it and won't overwrite the HD until you click on the iso button on the desktop. It is a good idea to be connected to the internet when installing .
    In your case why not just swap out the HD for another and test it out on that. Then you can always put the other HD back.
    One very good think with linux is that you can generally move HD's around from machine to machine without issue.
    If anybody is interested.
    I am considering making a post about the HAL and INI files to simplify or try to explain what they and how they work as I know there is a lot of confusion around this. But as you know I am not good at explaining stuff.
  5. The Following User Says Thank You to Clive S For This Useful Post:
  6. #5
    I'd prefer to install - then I can go a long way to breaking things with other package installs etc, configuration, customisation, but with a view of stepping back from the cliff and recovering back to normal if it all goes wrong.
    Sigh!, you must think I've hard-drives just lying around.... Oh!, I do. Fair point, will take that approach (though will need to copy my machine installation first.
    Happy to review technically if you want a second pair of eyes. No ulterior motive other than knowing it can be useful having a second pair of eyes/perspective. Does it belong here?, possibly not, but although there is substantial documentation on LinuxCNC sites/forums, it's very regimented and fragmented, and doesn't bring different topics together well.
  7. #6
    I can confirm that when you start the pc with the mint iso from either a pen drive or dvd it does not install mint instead it loads mint and lets you look around and run linuxcnc but will not save any configs. You can run the jitter year etc but I did get slightly worse results until I installed mint on the hdd
    If you are happy with mint then there is an ‘install to hard disk icon’ icon on the desktop. Click this and it’s all done in a matter of 10mins
    All the best. Paul
  8. The Following User Says Thank You to depronman For This Useful Post:
  9. #7
    Yes we live not very far away from each other
    Not sure I fully understand you last post
    Paul
  10. #8
    Quote Originally Posted by depronman View Post
    Unwarranted concern that I'd have to make system changes that would need to be committed to disk and rebooted (e.g. network configurations across twin NICs, including static configuration for the Mesa-based LAN interface (separate to the main interface) - usually if you have to tweak system files you're either restarting services or rebooting. My expectation was that the install was booting from a read-only filesystem into ram - I think that's what the Debian install does (can't remember now), BUT... just tried a boot from USB and was able to copy my machine config over, rebuild my custom HAL components, uplift my machine configuration automatically) and got the lathe running under Mint/LinuxCNC 2.8 within about 10 minutes.
    Too late to cancel the same-day order for the removable drive-bay adapter.
    Mint looks, for the 15 minutes I've played with it, much more comfortable than Debian.
  11. #9
    Yes I would agree on the mint look and feel over Debian
    Good result on the swift changeover
    I have a couple of hard drives with a Debian setup on my orac lathe. I’m feeling the need to move that to mint as well. But really need to concentrate on the boxford atm
    Paul
  12. #10
    Hi All,
    Just adding my name to the Linux / Mint / LinuxCNC party going on here. This will be the basis for my Boxford tcl240 conversion that I know a few of you have already commented on (thanks). I snagged a PC yesterday, and have collected a screen and some other bits and pieces together, and now have the prepackaged Mint/Linux iso waiting on a usb drive (thanks for the link) and GParted on a CD ready to get to work on an old hard drive..... I'll let you know how I get on once Ive located a VGA cable to plug my monitor in!
    Ade
  1. FOR SALE: Boxford MT2 & Boxford TCL125
    By jonnydeen in forum Items For Sale
    Last Post: 12-11-2021, 11:24 AM
  2. New Spindle drive Boxford V190 VMC
    By mosoeng in forum Boxford Vertical Mills
    Last Post: 19-09-2019, 09:11 AM
  3. SOLD: Boxford 260 VMC
    By Woodfish in forum Items For Sale
    Last Post: 11-12-2018, 08:34 PM
  4. Replies: 2
    Last Post: 21-04-2016, 09:18 AM
  5. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
