    I have a PDF copy of an Anilam display manual for the MiniWizard and Wizard displays (it says...) Not sure if there is a specific lathe version mentioned but it might help.
    I had a MiniWizard on my Smart and Brown when I bought it, although when one of the scales failed I ended up replacing the whole lot with an Easson setup. Still have the display head sitting under a bench somewhere - I think that that bit was OK. FWIW, my display is very similar although not identical to the one you show, except that mine says "Miniwizard."
    PM me your email address and I can send you a copy of the PDF.
  1. CONVERSION: Replacing elderly Anilam 1100 control system on vertical mill
    By Neale in forum Conversion Build Logs
    Last Post: 16-11-2020, 03:33 PM
  2. Upgrade questions fro beaver mill VBRP Mk2 with Anilam Crusader II controls
    By Breg90 in forum Milling Machines, Builds & Conversions
    Last Post: 25-05-2020, 08:08 PM
  3. Anilam Crusader 11
    By Frasbrown in forum General Discussion
    Last Post: 19-03-2020, 12:46 PM
  4. Anilam 1100m
    By blakey235 in forum Machine Discussion
    Last Post: 02-08-2014, 01:10 PM
  5. Replies: 0
    Last Post: 08-07-2014, 03:11 PM
