Page 3 of 3 FirstFirst 123
  1. #21
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by Manny View Post
    Hi Thanks for the reply
    Where did you connect the sensor to as I can not see a spare connection on the board and or rs connector
    Attachment 29246
    If the mill has been converted to Mach 3, then those wiring diagrams will most likely not apply.
    Also, Denford never had an option for a touch probe, so there will be no dedicated wiring in the original Harting connector for one. You'll either need to see if there are any redundant wires in the plug from the retrofit, add new pins, or run wiring externally for a touch probe.
  3. #23
    I ran an external wire
  1. Upgrading a Denford Triac Mill
    By Matabele in forum Denford Mills
    Last Post: 27-01-2022, 07:15 PM
  2. Denford or Boxford CNC mill - which is best?
    By GND in forum Milling Machines, Builds & Conversions
    Last Post: 07-10-2018, 07:37 PM
  3. Denford Triac Mill
    By DaveMann in forum Denford Mills
    Last Post: 12-01-2017, 10:43 AM
  4. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  5. WANTED: Wanted Denford Triac CNC Mill
    By angusnoble in forum Items Wanted
    Last Post: 15-07-2012, 06:45 PM
