    The simplest and cheapest way to get an accurate idea of the position would surely be to use an off-the-shelf DRO unit - you'd still need to manually wind the blade up and down though. Adding a motor (geared) to do that with UP and DOWN switches wouldn't be difficult either, but I've not seen a control unit for sale that would let you set the height - unless a plasma torch unit could be adapted maybe??
    Hi Voicecoil.
    If I understood right from what you said, a DRO unit is just an indicating unit. It is not a bad ideea, but I am inclined to attemt to make a magnetic device with a dial indicator on top, or something far more simpler (I do not know what yet :P) that serves the same purpose. I'll keep in mind the ideea. There are a few unit on ebay that can indicate 2 axis, and come with glass scales, around 200$ + transport. The approach it different from what I had in mind. (one home switch that zeroes the blade, and then a metric command given to a motor), but it might still work. Thank you.
  1. Replies: 7
    Last Post: 16-11-2019, 04:58 PM
  2. WANTED: cnc plasma table or in parts
    By whensparksfly in forum Items Wanted
    Last Post: 07-12-2014, 12:48 PM
  3. RFQ: Rising block for Tom Senior M1
    By rnr107 in forum Projects, Jobs & Requests
    Last Post: 24-12-2010, 07:06 PM
  4. the rising tide!
    By ptjw7uk in forum General Discussion
    Last Post: 21-11-2009, 09:46 AM
  5. OT Not cnc'ed but a very nice mechanism
    By BillTodd in forum General Discussion
    Last Post: 01-06-2009, 07:08 PM
