    I have a Chinese 6040Z 4 axis machine which I purchased some 4 years ago, and to date I have not managed to understand the Mach 3 programme, so have never used it. Anyway I wanted to fit home limit switches on it first, I was reading the thread on here about fitting and wiring but, the pcb inside my controler does not have any connection point for them, it looks nothing like the ones in the ohotos, there is a hole at the rear of the unit marked probe, but nothing on the pcb lining up with the hole.
    Can anyone help with this issue.
    next question will be is there a free or inexpensive operating programme that is easier to understand than the Mach 3?
    Doddy's Avatar
    First point: Here's a hint - you've described that the PCB is nothing like any other photo of PCBs... so we're as blind to this as you are. Take a good hi-res photo of the PCB and post it here.
    Second point: Mach3 - I hate it (mainly for the ye-olde windows experience) but it is fairly straight-forward and there's plenty on here that know it well... better/more than any freely available alternative. I'd stick with Mach3 for now (provided that you have a machine that runs it). There's plenty of tutorials online and if you invest a bit of effort then people here will typically help.
    don't know how to post a picture which I haven't got anyway but here is the link for the thread I was reading
    https://www.cnczone.com/forums/chine...ing-limit.html
    There are quite a few Divas on here but I haven't seen any mystic Meg's yet and we can't afford crystal balls so your going to have to give us clue.!
    Mach3 doesn't get any easier to use and to be honest just about every control software out there works the same regards cutting parts. ie: you load G-code, set Zero for each axis then push cycle start.!
    Mach3 needs setting up with the correct pins and motor tuning setup before it will work correctly. But this is the same for every other control software and it's just part of setting up the machine and control software.
    If you are struggling with Mach3 then you won't find it any easier using a different software and NONE of them will set your machine up automaticly, even if they say they do, because every machine is different and can be wired in many ways. with the Chinese machines, you have a box of chocolates in that you never know what you going to get, hence why it looks different to all the others.!
    Help us help you by giving better info, if not then we can't help it's that simple.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  6. #5
    Thanks for all your replies
    I
  7. #6
    Quote Originally Posted by RichardR View Post
    Thanks for all your replies, please no more replies there is no need to talk down to someone that is not as clever as you lot, I have never given up on anything and I will get there without any more help from this forum.
    I
    We are not talking down we are pointing out, in a light-hearted way, that you are not helping by not giving us the information we need to help you. But I can tell you this if you are going to be a snotty snow flake and give Zero info then you'll get very similair replies from just about any forum.
  8. #7
    My second post saying I did not know how to post a picture that was requested, was ignored, but still I had snotty replies, I will sort Mach3 out, my initial enquiry was about connecting the home switches up, re the link of the thread I was following, I should have asked on that old thread I may have got a bit more help than you experts are giving, sorry not normally like this but You all latched on to the Mach3 bit and ignored my plkea for help, 1 the pcb and 2 the posting of a picture.
    I rest my case and goodnight
  9. #8
    Doddy's Avatar
    Sorry - as you say, PCBs vary so I'm not going to speculate on an unknown board.
  10. #9
    Jazz makes good points here, add to those that if Mach3 was bundled with your machine it is likely a hacked pirate version.
  1. Original drivers & software for USB version CNC6040z?
    By craigrobbo in forum Machine Discussion
    Last Post: 29-09-2020, 08:17 PM
  2. Help with 2 problems re my CNC6040z please
    By craigrobbo in forum Gantry/Router Machines & Building
    Last Post: 29-09-2020, 06:51 PM
  3. Usb controller
    By pemmott in forum Artsoft Mach (3 & 4)
    Last Post: 02-12-2019, 07:34 PM
  4. !need Help CNC6040Z USB Limit switch wiring!
    By Schematicsman in forum General Electronics
    Last Post: 07-02-2018, 06:49 AM
  5. Controller Box
    By M250cnc in forum Motor Drivers & Controllers
    Last Post: 21-11-2010, 01:34 AM
