    Hi
    Have many people successfully converted a manual mill such as my Warco WM 18 to CNC? Or would I be better of buying ready made like Denford etc? I am no electronics wizard, I want to do light motorcycle and model engineering projects in a small home workshop. CNC4YOU do kits that are quite expensive and not sure they work well. Budget 2-3k.
    Quote Originally Posted by Alan_Kinsey View Post
    Hi
    I've done an Amadeal AMAT25LV.
    1605 screws with double nuts. It is pretty solid. All bearing carrier and nut components custom.
    Basically you need a mill to convert a mill, lol.
    If a light machine is all you need then prob get pre built. It will have low limitations though, steel components a delicate long process.
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 20 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    +1, with a Sieg SX2.7L conversion - again, 1605 screws and replacing the spindle motor/control electronics.
    The electrical side of things isn't necessarily complicated, it's the machinal stuff that needs care as you're taking a machine out of commission whilst you fettle and fit. Worthwhile, but effort - if buying from scratch a dedicated CNC machine is likely a better (and more expensive) solution.
  1. FOR SALE: Warco VMC for sale - Perfect for conversion
    By Jools in forum Items For Sale
    Last Post: 29-07-2020, 02:41 PM
  2. BUILD LOG: Warco WM16 CNC Conversion.
    By noyloj in forum DIY Mill Build Logs
    Last Post: 21-01-2017, 09:19 PM
  3. Warco WM16 Conversion
    Last Post: 25-03-2011, 09:32 PM
  4. Warco mini mill cnc conversion
    By buster in forum Milling Machines, Builds & Conversions
    Last Post: 20-03-2011, 07:48 PM
  5. CONVERSION: Warco VMC Turret Mill - CNC Conversion
    By antsals in forum Conversion Build Logs
    Last Post: 07-03-2011, 12:25 AM
