Thread: 6040Z controller
19-10-2020 #11
There's some silk-screen printing on the board (first pic) - a box surrounding a 2x3 grid of holes filled with solder, with XYZ printed against these. You'll need a bit of solder wick to clean the solder out of the holes/pads, then get a 2x3 0.1" pitch header, insert into the board and solder in place. Then you need a a cable form to connect into there (many choices, google Dupont connectors) - to make off the cables for the axis sensors. and run these to each of the three axis microswitches.
19-10-2020 #12
19-10-2020 #13
Thanks, What about the Probe, I presume I need to get the correct socket for the probe lead, solder that to the three holes and take two wires to the solder pads marked Probe
19-10-2020 #14
I have had a look on amazon but there are so many sizes, but cant seem to find anything 0.1 in size, I would like to fit some sort of connecter on the back of the unit so I can actually plug the wires to the limit switches into that
19-10-2020 #15
Looks like, from here, a 3.5mm jack socket, or a barrel-jack, something like...
But without measuring kinda guessing.
You'd use EITHER that or add another 2-pin connector to the Probe inputs, then take the wires to the probe.
EDIT:
Okay, just read your reply - yeah, it could be a good idea to eat some holes into the case and mount some appropriate chassis connectors, then route these back to this board.
21-10-2020 #16
Thanks for your help, sourced the parts I needed and you were spot on with the pitch of the pins,I got all I need from radio spares except the jack socket for the probe, I think I failed to add one to my order and never noticed.I
The six micro switches are all fitted, just need to wire them up, can you tell me the best way to wire them bearing in mind the controller I have and the Mach3 operating software, in parallel or series?
21-10-2020 #17
You don't "need" the jack - you could just use a pair of the 0.1" headers and a 2-way socket. But horses for courses.
You don't need independent X/Y/Z inputs - you could wire all microswitches, normally-closed contacts in series. Or, keep it simple and wire each pair for each axis in series.
I would recommend reading the Mach3 manual - it deals with this quite well. In particular read up on homing switches and soft-limits.
21-10-2020 #18
Thanks for that, the pcb has three holes for a Jack socket and a hole in the cabinet that lines up with it also marked probe, so I thought I would use it, I have decided to take things one step at a time, however I have been reading older threads dealing with limit switches and Home switches, I am now not sure whether I am doing things correctly, as I initially thought they were the same thing, on the pcb it has a 2x3 pin header marked XYZ is this for home switches or limit switches?
21-10-2020 #19
Just re-read your reply now I am confused, limit switches, homing switches and soft limit switches?
21-10-2020 #20
Limit switches I think you understand already. Home switches are used to establish a position on an axis. Soft limits are software imposed limits, given a known reference point (eg home position). So with homing sensory/switch and soft limits you don’t “need” limit switches. It’s all in the manual.
6040Z USB CNC - USB port not recognised.
By Roy in forum Chinese MachinesReplies: 9Last Post: 23-05-2021, 10:04 AM -
Usb controller
By pemmott in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 02-12-2019, 07:34 PM -
6040Z USB connection issues
By rogw in forum Chinese MachinesReplies: 8Last Post: 01-08-2019, 08:30 PM -
CNC 6040z USB z-axis
By Sashido in forum Chinese MachinesReplies: 19Last Post: 26-03-2018, 09:46 AM -
Engraving small font - the bit digs deeper and deeper as the job goes on. 6040z
By xoneeleven in forum Chinese MachinesReplies: 46Last Post: 26-04-2016, 12:06 AM
