Thread: 6040Z controller
The other advantage of soft limits is that mach3 won't let you jog into the limits and slows the machine to a nice controlled stop. It also checks your G-code and if you are going to pass the soft limits warns you.
Home switches are priceless and if you are going to the trouble of fitting limits you'd be silly not use them as home switches as well.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
22-10-2020 #2
Just to add to Jazz's comment, and possibly to head off the next question, apart from position (limit switches on the extremes of travel, home switches at some arbitrary position within the extremes of travel - possible a limit switch) - the distinction is made within the Mach3 settings - you'll bind an input (Pin 11/12/13 - assume X/Y/Z, according to the silk-screen printing on the board) to a function (limit/home) within the Mach3 inputs, then Mach3 takes over from there.
6040Z USB CNC - USB port not recognised.
By Roy in forum Chinese MachinesReplies: 9Last Post: 23-05-2021, 10:04 AM -
Usb controller
By pemmott in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 02-12-2019, 07:34 PM -
6040Z USB connection issues
By rogw in forum Chinese MachinesReplies: 8Last Post: 01-08-2019, 08:30 PM -
CNC 6040z USB z-axis
By Sashido in forum Chinese MachinesReplies: 19Last Post: 26-03-2018, 09:46 AM -
Engraving small font - the bit digs deeper and deeper as the job goes on. 6040z
By xoneeleven in forum Chinese MachinesReplies: 46Last Post: 26-04-2016, 12:06 AM
