Thread: 6040Z controller
25-10-2020 #12
No I was not aware of that, so I need to take all the earths separately to a connection on the back of the machine, choc strip, then one wire to the bolt on the control box?
While I am on I wonder if you can help with the amount of travel of the Axis, for instance the machine is set up for mm however the actual movement on the axis's do not correspond with the amount that was inputted. I presume that if I enter G0 X10 then it should move 10 centimetres but it only moves approx. 6 centimetres. Am I correct in thinking that if I enter a code of G0 X0.05 then it should move 5mm. I get very confused with Metric but I have a feeling that the 6040 has a metric screw thread, although I cannot find any information on it now.
6040Z USB CNC - USB port not recognised.
By Roy in forum Chinese MachinesReplies: 9Last Post: 23-05-2021, 10:04 AM -
Usb controller
By pemmott in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 02-12-2019, 07:34 PM -
6040Z USB connection issues
By rogw in forum Chinese MachinesReplies: 8Last Post: 01-08-2019, 08:30 PM -
CNC 6040z USB z-axis
By Sashido in forum Chinese MachinesReplies: 19Last Post: 26-03-2018, 09:46 AM -
Engraving small font - the bit digs deeper and deeper as the job goes on. 6040z
By xoneeleven in forum Chinese MachinesReplies: 46Last Post: 26-04-2016, 12:06 AM
