Thread: Any VFD gurus' out there?
21-10-2020 #5
Hi (again) from what I have read (and possibly misunderstood) I have two options:
a) start both the motors at the same time in which case the VFD controls the ramp up speed of the motors so the VFD can be sized by adding the power requirements of the two motors.
b) If both motors aren't started at the same time then the VFD must be sized by adding the FLA of the motor started first to the locked rotor amps of the second motor.
Thsi is where it all becomes hard for me to follow - why do they mix HP and Kw confuses me.
https://www.automation.com/en-us/art...ultiple-motors
At this point I am leaning towards wanting to turn on the dust extractor independantly so I can use it with another machine as well as the grinder in which case I think it best to either get another VFD for it or convert it to 240V unless I put a switch in that would make the dust extractor become the primary motor instead of the grinder. Both motors being the same size helps here (I think).
Solidworks gurus
By D-man in forum SolidworksReplies: 16Last Post: 06-12-2014, 03:21 PM -
Any CUT3D Gurus Out There?
By Washout in forum VectricReplies: 4Last Post: 20-06-2014, 08:27 AM -
Calling all laser gurus
By D-man in forum General DiscussionReplies: 0Last Post: 22-09-2009, 08:16 PM
