16-11-2009 #2
Hi scotty,
Welcome to the forum. Have you got any pictures of the machine you've bought? I'm guessing that because you're thinking of upgrading it, that the BBC computer isn't working?
You need to work backwards from the motors. Steppers or servos? (steppers probably have 4 or 8 equally sized wires going to them, whereas servos will have 2 fatter wires and 4 or so much smaller wires).
The motor type decides what controller to buy. Which controller are you thinking of?
Once the controllers are decided you need to wire it up to a PC.
The PC then runs software like Mach3 (not free but well-documented), or EMC (free, and getting simpler by the day).
I hope this helps - it would be great to see some pics...
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Y axis is making X axis stall...!!
By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
