Scotty,
Well assuming the steppers are OK, you'd need a suitable driver/interface package, which could be as little as £70 or as much as you'd lke to pay, and a PC running Windows/Mach3 or Linux/EMC...
So your first port of call is to determine what stepper motors are fitted...
22-11-2009 #2
Thanks for the help what I know is spindlemotor varible speed dc
size md 7175
stepper hy200-3424--170a8
stepper hy200-2220-100a8
been advised that a CDE m401 controller and a step1motor card
should do the trick with free software being a newbie I am looking for
the best and easiest option here.
thanks
scotty
22-11-2009 #3
From what I can find out, the 3234-170 is a Nema34 size 1.7A 1.7Nm motor, and the 2220-100 is 1A Nema23 0.7Nm size. These are old motors and might be worth considering replacing them eventually... but initially they would be OK. I've attached the data sheet..
Accordign to CDE's weboste the M401 is £200 and the two Step1 cards £50 each, so you are looking at £300 and these are 3.5A cards which are overkill for the motors you have - this assumes you can reuse the existing power supply. There are other options, and by way of example, a 2-axis System4 with 2.5A cards, including power supply (if needed) from DIYCNC.co.uk would be around £120 (£90 without), and the free version of MACH3 would do to learn on...
11-12-2009 #4
Ok ordered the new parts last week inc new power supply can't wait
to get started
11-12-2009 #5
11-12-2009 #6
Just as you advised:-
and thanks for all your help for pointing me in the right direction;
system 4 main board,
two 2.5a bipolar stepper motor drive cards,
a spindle control module card,
and power supply
I'm looking forward to the rewire and getting it up and running.
12-12-2009 #7
18-12-2009 #8
Well the parts arrived yesterday I have been hard at it
the photos are on there way everythings gettin there
just a few things am stuck with stepper motor wires each has 8
which do i use for the drive cards
orange and white/ black and white both pair joined
red and white/yellow and white both pair joined
black,red,orange,yellow.
also do I use the potentiometer wires black,red,blue
and below/ connected to the spindle motor there is an inductor
there are 4 wires here two large black,red the red runs into the inductor
and two small wires pink/white.
http://i60.photobucket.com/albums/h2...s/lathe001.jpg
http://i60.photobucket.com/albums/h2...s/lathe003.jpg
http://i60.photobucket.com/albums/h2...s/lathe012.jpg
http://i60.photobucket.com/albums/h2...s/lathe014.jpg
http://i60.photobucket.com/albums/h2...s/lathe017.jpg
http://i60.photobucket.com/albums/h2...s/lathe019.jpg
http://i60.photobucket.com/albums/h2...s/lathe020.jpg
http://i60.photobucket.com/albums/h2...s/lathe021.jpg
http://i60.photobucket.com/albums/h2...s/lathe023.jpg
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Y axis is making X axis stall...!!
By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
