Ok ordered the new parts last week inc new power supply can't wait
to get started
11-12-2009 #2
11-12-2009 #3
Just as you advised:-
and thanks for all your help for pointing me in the right direction;
system 4 main board,
two 2.5a bipolar stepper motor drive cards,
a spindle control module card,
and power supply
I'm looking forward to the rewire and getting it up and running.
12-12-2009 #4
18-12-2009 #5
Well the parts arrived yesterday I have been hard at it
the photos are on there way everythings gettin there
just a few things am stuck with stepper motor wires each has 8
which do i use for the drive cards
orange and white/ black and white both pair joined
red and white/yellow and white both pair joined
black,red,orange,yellow.
also do I use the potentiometer wires black,red,blue
and below/ connected to the spindle motor there is an inductor
there are 4 wires here two large black,red the red runs into the inductor
and two small wires pink/white.
http://i60.photobucket.com/albums/h2...s/lathe001.jpg
http://i60.photobucket.com/albums/h2...s/lathe003.jpg
http://i60.photobucket.com/albums/h2...s/lathe012.jpg
http://i60.photobucket.com/albums/h2...s/lathe014.jpg
http://i60.photobucket.com/albums/h2...s/lathe017.jpg
http://i60.photobucket.com/albums/h2...s/lathe019.jpg
http://i60.photobucket.com/albums/h2...s/lathe020.jpg
http://i60.photobucket.com/albums/h2...s/lathe021.jpg
http://i60.photobucket.com/albums/h2...s/lathe023.jpg
19-12-2009 #6
I have looked every where for info on this lathe can't get much
if anyone has a manual a copy would be most appreciated.
scotty
09-01-2010 #7
Just a wee update; I managed to get hold of a connect 121 manual and a mach3 tut printed version and I have saved it to usb. also I now have a fully working cnc lathe. Woo Hoo! and a big thanks to Irving for helping me out with lots of much needed info. The motor control card was busted so I ordered a new one and now we are now up and running. I just need to learn how to draw in cad and which software to get. I think if I can get into the swing of things I will keep it. Failing that it's going back on the bay and hopefully i will get a manual one.
09-01-2010 #8
well done Scotty, and thansk for the thanks :)
you can always drive the CNC lathe manually via MACH3... easier still with a pendant... here is a nice homebrew example but you can buy commercial ones...
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Y axis is making X axis stall...!!
By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
