    Well the parts arrived yesterday I have been hard at it
    the photos are on there way everythings gettin there
    just a few things am stuck with stepper motor wires each has 8
    which do i use for the drive cards
    orange and white/ black and white both pair joined
    red and white/yellow and white both pair joined
    black,red,orange,yellow.
    also do I use the potentiometer wires black,red,blue
    and below/ connected to the spindle motor there is an inductor
    there are 4 wires here two large black,red the red runs into the inductor
    and two small wires pink/white.
    http://i60.photobucket.com/albums/h2...s/lathe001.jpg
    http://i60.photobucket.com/albums/h2...s/lathe003.jpg
    http://i60.photobucket.com/albums/h2...s/lathe012.jpg
    http://i60.photobucket.com/albums/h2...s/lathe014.jpg
    http://i60.photobucket.com/albums/h2...s/lathe017.jpg
    http://i60.photobucket.com/albums/h2...s/lathe019.jpg
    http://i60.photobucket.com/albums/h2...s/lathe020.jpg
    http://i60.photobucket.com/albums/h2...s/lathe021.jpg
    http://i60.photobucket.com/albums/h2...s/lathe023.jpg
    I have looked every where for info on this lathe can't get much
    if anyone has a manual a copy would be most appreciated.
    scotty
    Just a wee update; I managed to get hold of a connect 121 manual and a mach3 tut printed version and I have saved it to usb. also I now have a fully working cnc lathe. Woo Hoo! and a big thanks to Irving for helping me out with lots of much needed info. The motor control card was busted so I ordered a new one and now we are now up and running. I just need to learn how to draw in cad and which software to get. I think if I can get into the swing of things I will keep it. Failing that it's going back on the bay and hopefully i will get a manual one.
  4. well done Scotty, and thansk for the thanks :)
    you can always drive the CNC lathe manually via MACH3... easier still with a pendant... here is a nice homebrew example but you can buy commercial ones...
  1. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  2. 4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
    By TommeyReed in forum Motor Drivers & Controllers
    Last Post: 06-03-2012, 06:01 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Y axis is making X axis stall...!!
    By fasteddy in forum Machine Discussion
    Last Post: 24-10-2011, 12:19 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
