Thread: moving gantery CNC sturdiness
#1 Yes it will vibrate for sure, the question is how much and this we can't answer because too many variables involved. However, your needs cutting plywood are not taxing so it will probably easily fullfill your main needs, Cutting aluminium on the other hand is different and here it could struggle with vibrations leaving a poor finish.
#2 It's not that simple I'm afraid which is what I was trying to tell you before in my post about the motors.
You can't simply increase the speed of the steppers because as the RPM increases torque drops and because you are using a 5mm pitch you'll need 1200rpm to reach 100mm/sec which those motors won't provide enough torque at those speeds to turn 20mm screws. There are other factors due to resonance and whip which will also come into play and make it not happen.
Again I'll say it because it's VERY important, the Drives and the voltage you run the motors at make a big difference to performance and they need to match to get the best from them.
#3 Pay the extra and get 10mm pitch or even 20mm. You think your saving money by buying 5mm but what your actualy going to do is waste money because you'll soon realise after it's too late you can't reach the feeds you'll need and then you'll be stuck with them.
Now the reason why a larger pitch is better is two fold,
#1 Is obvious in that It gives you the feeds you require
#2 It means you can reach the feeds at a lower RPM which means you have higher torque as the motor is operating lower down the speed curve while cutting and the screw speed is lower so less chance of whip.
These Kits are false economy and nearly always made up of cheap components or poorly matched components. DONT DO IT is my advise, buy separate components that are better matched.
Also Like A_Camera says and I failed to spot first time you have NO CHANCE of building this for 1000 euro's, you'll need at least twice this to make it worth the time and effort.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
3018 not moving
By Steve T in forum Chinese MachinesReplies: 1Last Post: 17-04-2020, 07:35 PM -
Moving a machine
By FlyingHaggis in forum General DiscussionReplies: 4Last Post: 15-11-2019, 04:04 PM -
Help Please for Moving Gantry
By endlasuresh in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 08-11-2017, 12:15 PM -
Help! Moving a big lathe...
By Jonathan in forum General DiscussionReplies: 21Last Post: 27-12-2015, 11:54 PM -
FOR SALE: Selling due to moving to Oz
By r0bsk1 in forum Items For SaleReplies: 7Last Post: 23-09-2014, 11:02 PM
