Thread: usb6560 Axis4 - Spindle speed
Hi Dave,
Welcome to the forum.
M3, M4, M5 are G-Codes, and they instruct the machine to Start the Spindle Clockwise, Anti Clockwise, and Stop respectively. For a hobby CNC, you probably only need to worry about M3 and M5.
The controller you've mentioned, if I'm looking at the right manual (link below), has a relay for the spindle control. When the controller receives an M3 code it will trigger this relay. A should be normally open, B should be normally closed. The COM is the common.
The manual talks about speed control, but doesn't suggest a pin to set it to, so I suspect this is just an "On/Off" for the spindle via this relay.
To help further, we'd need to know more about your spindle and the spindle controller you're using. Photos (once you've got 10 posts under your belt) are always useful.
https://www.cnczone.com/forums/attac.../428470.attach
HY VFD and spindle at low speed
By Neale in forum General ElectronicsReplies: 9Last Post: 26-09-2018, 08:47 AM -
Spindle Speed Control
By Kev2960 in forum Chinese MachinesReplies: 5Last Post: 17-02-2017, 07:08 AM -
Irregular Spindle Speed
By HipoPapi in forum Spindles & Drive MotorsReplies: 26Last Post: 07-07-2016, 06:07 PM -
So Nearly there - Mach3 and VFD Spindle Speed.
By davegrennan in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 11-04-2015, 12:30 AM -
High speed spindle
By leadinglights in forum Tool & Tooling TechnologyReplies: 0Last Post: 27-04-2010, 09:23 PM
