Thread: Circuit breaker and fuses
03-11-2020 #6
Not sure that surge is as much a problem with SMPS as with a linear supply as the storage capacitors are much smaller, but there will be some. Frankly, it's all a bit finger in the air but for what it's worth, I have a machine with 4 steppers. drivers set to deliver around 4A each at a nominal 70V. That's about 560W as I assume that only two steppers are taking full current at any one time. As I say, there's a fair bit of guesswork in all this! The rest of the control box (motion controller, relays, etc) take so little that they aren't worth considering. However, I have fitted a 10A D curve MCB. 10A gives headroom to allow for switch-on surge for the linear supply, and the D curve is there as it has a slower response time to help with this.I am confident that even with a major fault internally the MCB will trip before the wiring bursts into flames - and, frankly, that's the only protection that the MCB gives.
One MCB for the whole box - I don't feel that there is much point in a separate MCB per driver as some people do. At least my way if the MCB trips then everything is going to stop rather than just one axis. But.- you pays your money and you takes your choice.
Denford Micromill 2000 no power - is there more than two fuses?
By fireburst in forum Denford MillsReplies: 2Last Post: 15-06-2018, 09:20 AM -
Fanuc OT - Fuses blowing
By Cube3 in forum Machine Control SoftwareReplies: 7Last Post: 19-07-2017, 08:03 PM -
HEIDENHAIN VRZ 731B - Blowing Fuses
By goweruser in forum General ElectronicsReplies: 2Last Post: 06-02-2017, 10:52 PM -
-10V to 10v circuit
By vre in forum General ElectronicsReplies: 17Last Post: 15-01-2014, 12:15 AM -
3 axis driver...Fuses keep blowing
By dudz in forum Motor Drivers & ControllersReplies: 5Last Post: 28-01-2013, 08:05 PM
