Thread: DIY CNC Mill Build vLog
10-11-2020 #3
Really you would have been better leaving a small gap between the base frame plate and the column plate then fitting some grub screws in the Coloumn base plate so you could set the coloumn true. This way you can fine tune the column with the rails etc fitted using proper setup tools like dail gauge's rather than cheap set squares which are just not accurate.
Then when it's all setup fill the gap with Epoxy metal putty, spray the coloumn plate with a release agent or tape the surface and you can still remove when needed. This process works very very well when you can't machine the surfaces.
Edit; Oh and the music on those Vids is annoying ASF...-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
BUILD LOG: Epoxy granite vertical mill build log
By Nick in forum DIY Mill Build LogsReplies: 60Last Post: 08-06-2020, 06:30 AM -
BUILD LOG: Build Log: 3-4 Axis Mill/Router
By IanS1 in forum DIY Router Build LogsReplies: 35Last Post: 24-10-2014, 02:12 PM -
BUILD LOG: Advice sought on new Mill build
By embraced in forum DIY Mill Build LogsReplies: 40Last Post: 02-10-2014, 05:36 PM -
New CNC mill build
By AVRnj in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 13-04-2013, 12:19 PM -
BUILD LOG: Quirky Turn Mill Build
By vtcnc in forum DIY Router Build LogsReplies: 8Last Post: 16-09-2012, 02:53 AM
