    Is there anything that will cause a problem if I install a stepper driver into the control cabinet but do not always have the 4th axis stepper motor connected to the driver. I would turn the mill off before either conencting or disconnecting the 4th axis stepper motor
    simple question is will it harm the stepper driver if powered up but not stepper motor connected to it ?
    If this is a problem would fitting a switch in the stepper driver power feed be the right resolution ?
    Cheers,
    Paul
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 8 Hours Ago Has been a member for 8-9 years. Has a total post count of 490. Received thanks 81 times, giving thanks to others 27 times.
    Shouldn't bother the driver, as long as (as you say) you don't disconnect the motor when its actually powered up.
    On my 4th axis, I isolate the mains feed to the servo drive by flicking a circuit breaker to save power etc when not connected. That's a simple and safe way to do it. No point having it powered up and doing nothing.
    If your system requires all axes to be homed before you can use it, you might have an issue. On my Acorn system you can turn off the 4th axis and also disable homing for 4th axis anyway. Similarly, if you have an error / status signal back from the driver to your controller, you'd need to check it wouldn't cause an issue.
    Quote Originally Posted by Muzzer View Post
    Excellent I will arrange a switch to break the power on the A axis stepper driver. Agee with no point having it power up when most of the time it will not be used
    I think I configure linuxcnc to not home the A axis no switches on it any way
    Cheers. Paul
  1. Mini 5 axis cnc mill
    By andy_con in forum Machine Discussion
    Last Post: 16-12-2015, 09:46 PM
  2. BUILD LOG: Build Log: 3-4 Axis Mill/Router
    By IanS1 in forum DIY Router Build Logs
    Last Post: 24-10-2014, 02:12 PM
  3. BUILD LOG: 3-Axis CNC Mill Project
    By Hobgoblin in forum DIY Router Build Logs
    Last Post: 23-12-2012, 11:47 AM
  4. WANTED: 3-Axis Mill recommendations
    By TomB in forum Items Wanted
    Last Post: 05-10-2012, 10:06 AM
  5. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
    By LoveLearn in forum New Member Introductions
    Last Post: 25-01-2012, 08:46 PM
