Thread: second hand machine
	16-11-2009 #1
Hi ladies and gents.
I am very interested in buying a second hand CNC router, I don't have the time or equipment to build one, so I am looking for some help to source one. The projects I have in mind would require 600mm x 600mm x 200mm x,y & z working envelope. Any and all help would be gratefully received.
	18-11-2009 #2
Hi Steve,
Welcome to CNCUK...
What are you thinking of machining with your new router? That size would probably be one of the larger sizes owned on this forum (anyone, correct me if i'm wrong?). Depending on what you're cutting that size would need a well-built MDF machine, or an aluminium one... On the other hand if you're cutting foam only, you could get away with alot less.
If you give a few more details maybe someone will be able to help (or even build one for you!).
Tom
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Hand Ergometer
By irving2008 in forum General DiscussionReplies: 50Last Post: 11-08-2013, 05:55 PM -
Need a quick hand with some resitors please
By Fivetide in forum General ElectronicsReplies: 4Last Post: 07-04-2013, 08:58 PM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM
