  1. #6
    Paul,
    Much depends on your level of experience and your ability to pick a soldering iron up the right way
    Firstly, disclosure - I have a UC300ETH, however, I'd recommend the AXBB-E. Basically the brains of the UC300ETH coupled to a pretty robust break-out board (BoB). If you don't do this, you'd need to source a BoB anyway, and a 26->25 IDC header cable (at least!). It's just more faff. Another thing though - I'd examine your control box to understand the space envelope you have to play it, or, work out if your want to adapt of replace the control box (just the physical enclosure). Quarts don't fit into pint-pots, and recent experience with another's 6040 indicates the control boxes can be a bit pokey. Your experience may vary.
    Before seriously considering this - have a look in your control box and get a photo of the innards and post here - we'd have to understand if you have separate stepper drivers, or integrated onto the controller board. If the latter, you have a steeper cliff to climb. In principle the control box is very simple in design, but implemented in any number of cost-cutting ways, so it's hard to advise anything without eyeballing what you have.
    Heres what Im working with. The current controller is approx 110mm x 60mm. I like the sound of the AXBB-E and will gladly switch over to UCCNC. Tried to make a simple fixture today and it cut out about 30 times, becoming very annoying.
    The AXBB is 120mm x 97mm so it doesnt look like it will fit where the current controller is but could I just mount it in that spare stepper drive slot?
Name:	WhatsApp Image 2020-11-12 at 16.05.49.jpg
Name:	WhatsApp Image 2020-11-12 at 16.05.48 (2).jpeg
Name:	WhatsApp Image 2020-11-12 at 16.05.48.jpeg
    CNC: OMIO X4 800L
    HG15+20 Linear Guide Rails
    1605 Ball screws
    0.8kW Air-cooled spindle
  1. Replies: 2
  2. Miniature Lathe for Pen Turning - Brushed or Brushless Motor?
    By Nealieboyee in forum Gantry/Router Machines & Building
    Last Post: 29-10-2012, 11:34 PM
  3. cnc cutting tool tungsen caride milling and turning insert
    By pipiyjj in forum Manufacturer News
    Last Post: 22-03-2012, 02:43 AM
  4. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
  5. Air compressor - faulty, how do I get the motor out?!
    Last Post: 26-10-2009, 11:33 AM
