13-11-2020 #11
13-11-2020 #12
You'd keep the 40V for the stepper drivers. If necessary you could slave a very small 24V supply in there, or a DC-DC convertor to derive a 24V from the 40V. If you pursue this conversion I would at that time ask for more photos - I'm somewhat surprised that the control card takes in 40V - that's unusually high so it could be that there is another supply derived elsewhere (or otherwise regulated on the control card).
EDIT: Omio's website shows the USB control card, at a V2.2 - the V2.1 I can trace to a Canadian supplier and looks identical except for the 2.2 including screw-terminals (2.1 was wire-board connectors), BUT, it did specify a 12-24V supply for the controller, which makes me more convinced than ever that there is a 12-24V supply sourced within the control box - that should be sufficient for the AXBB-E.Last edited by Doddy; 13-11-2020 at 08:00 PM.
13-11-2020 #13-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Miniature Lathe for Pen Turning - Brushed or Brushless Motor?
By Nealieboyee in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 29-10-2012, 11:34 PM -
cnc cutting tool tungsen caride milling and turning insert
By pipiyjj in forum Manufacturer NewsReplies: 0Last Post: 22-03-2012, 02:43 AM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM -
Air compressor - faulty, how do I get the motor out?!
By HankMcSpank in forum General DiscussionReplies: 5Last Post: 26-10-2009, 11:33 AM
