Like I said the first time, it depends on the application if it's worth it or not. This machine has a specific usage (which I can't mention because of customer confidentiality) that doesn't require high strength so deflection won't be any concern even if it deflected 10x.
This is not my first rodeo, I wouldn't build something that wasn't more than up to the task it's been designed to do by a large factor.
If I was building a machine for cutting more aggressively and I will be very soon, then you'll see it's designed very different with much more bracing and thicker wall tubes, but it will still have the slots because they very much protect the screws. Also, you are making a big assumption that there is nothing inside those tubes.!!
I'd also be interested in the forces you applied to those tubes.? Are they realistic or would we need 30Kw servos with 2mm pitch 30mm ball-screws to repeat...
More than you think do care, also usually IMO when something looks wrong, it usually works wrong or awkwardly.
Racking can't NOT happen IMO when it's plunging into hard materials for operations like drilling, it's just by how much.?
The extra expense of making it more massive, etc to counteract this far outweighs buying another ball-screw as it doesn't stop at just the width, spacing, etc. As it gets heavier, wider, etc, it requires larger and more costly everything.
Doubling up means you share the loads so can use a smaller size and less expensive components which cancels out any cost offsets but gives a much better-balanced machine.!. . . Which looks like it was designed by someone who knows what there doing and not a tight-arse who's trying to save a few ££.
Well first I wouldn't use belts on something any wider than that little machine I did and I wouldn't use belts if I was chasing accuracy to the degree of mapping ball-screws as it defeats the point and like you say makes it very difficult.
Regards Screw mapping then very few do that at the DIY level and if using linear encoders rather than rotary encoders then you shouldn't need to map the screw. Your only concern then is keeping the two sides in sync and I'd assume if using linear encoders the control system will be fully closed-loop so will handle that side.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
06-12-2020 #2
That piece would not be machined assembled. It would be done in two pieces and then the hinges connected.
Your design won't machine that work in one piece anyway. Your cutting tool will be say 5mm, but 50mm higher in Z you will have your full spindle cartridge/Z axis to hit the piece standing up.
How much experience do you have machining / making parts?
Some of the issues you are trying to solve with machine design are actually fixturing issues.
No machine design will save you from forgetting to do something correctly.
Big Epoxy Granite machine, Which frame is better ?
By EZELab in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 18-09-2020, 11:18 PM -
BUILD LOG: Epoxy granite vertical mill build log
By Nick in forum DIY Mill Build LogsReplies: 60Last Post: 08-06-2020, 06:30 AM -
Large Format Epoxy Granite Gantry CNC - Looking For Feedback
By Max Maker in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2019, 04:57 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM
