19-11-2020 #21
Link to information that recommends a DC power supply for the servo driver?
19-11-2020 #22
19-11-2020 #23
Read the specification for you selected drivers.
You will always need part for control logic, switching etc., but if you have mains driven servo drivers then this would be a much smaller power supply, at lower voltage and power.
19-11-2020 #24
19-11-2020 #25
Some servo drives need only a AC supply, others need AC + 24V DC for the control logic.
In all cases you will still need a DC supply for the motion controller and other things. Basically a small switching PSU like this: https://uk.rs-online.com/web/p/din-r...plies/0428477/
04-12-2020 #26
gone
05-12-2020 #27
Why direct drive?
Won't it be much harder regarding drawbar etc?
05-12-2020 #28
gone
05-12-2020 #29
The Z looks complex. I assume you have a complete machine shop to build it. Ideally it should be as wide as the gantry carriage.
I would go fixed gantry for the relatively small working area you planned.
Maybe also consider simplifying the shape of the columns, but in the end you'll be the one to build the molds :)
05-12-2020 #30
I do not, all I have is a hand drill and a dremel, I'm outsourcing it. The sheet metal cutting and welding. It's not more complex then a straight or a C plate. It's just a square steel tubing in the end. I've actually received a quote for the whole piece from the local shop EUR600 total for the thing.
Besides the Z, nothing is final yet. I'd go with a fixed gantry but I haven't got a clue yet as to how I'd deal with the bed. What I mean by that is I want to be able to mount the 640x320 work piece vertically. With a moving bed, I don't have any ideas how to do that though.Last edited by hardenum; 05-12-2020 at 02:52 PM.
Big Epoxy Granite machine, Which frame is better ?
By EZELab in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 18-09-2020, 11:18 PM -
BUILD LOG: Epoxy granite vertical mill build log
By Nick in forum DIY Mill Build LogsReplies: 60Last Post: 08-06-2020, 06:30 AM -
Large Format Epoxy Granite Gantry CNC - Looking For Feedback
By Max Maker in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2019, 04:57 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM
