    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    There's nothing any more dangerous about a toroidal PSU versus any other PSU of similar voltage and wattage. However, I think you might be slightly confused though - I'd expect that you'd be buying the servo with a matching servo driver. Looking at lt Lichuan 60's on Aliexpress - that's certainly a common bundle. In which case - check the datasheet, but the servo drivers would likely be 220VAC mains driven, and in which case you wouldn't need the high power, high voltage toroidal PSU. Or maybe I'm too tired and I've missed a point in your post?
    I will definitely be buying a matching driver(amplifier) from lichuan. I really have no idea about powering electronics, I probably don't even know the questions I should ask. What's confusing me is that the servo's are AC and the recommended PSU outputs in DC.
  1. Big Epoxy Granite machine, Which frame is better ?
    By EZELab in forum Gantry/Router Machines & Building
    Last Post: 18-09-2020, 11:18 PM
  2. BUILD LOG: Epoxy granite vertical mill build log
    By Nick in forum DIY Mill Build Logs
    Last Post: 08-06-2020, 06:30 AM
  3. Large Format Epoxy Granite Gantry CNC - Looking For Feedback
    By Max Maker in forum Gantry/Router Machines & Building
    Last Post: 23-08-2019, 04:57 PM
  4. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  5. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
