Thread: Laser PSU tripping RCD
15-11-2020 #3
Please don't overside the RCD - there's no reason for this device, if working correctly, to pop a 10A RCD. If you want to follow that solution use a 6" nail instead.
I'm taking you at your word that the fault has been localised to the PSU - get that out of the unit.
Eyeball the feeds to the tube - check no debris or shorts to case.
Eyeball the PSU for debris.
Slave the PSU to a separate mains feed. First with the chassis earthed, then - carefully - without it earthed. That'd confirm any earth leakage through damage to either PSU or PSU enclosure.
Work safely!, 30kV at 30mA can end a life.
EDIT: I once popped a pipe off the tube and pissed water throughout the enclosure. Is there any chance of any residual water in the cooling jacket have been displaced into the enclosure?
Redsail M500 mini laser engraver needs a new laser tube ???
By shindax in forum Laser Machines & BuildingReplies: 4Last Post: 12-10-2019, 02:21 PM -
VFD Tripping an RCD
By Washout in forum Spindles & Drive MotorsReplies: 13Last Post: 04-09-2017, 02:07 PM -
RCD tripping
By Saracen in forum General ElectronicsReplies: 6Last Post: 22-01-2017, 12:52 AM -
RCD tripping
By motoxy in forum General ElectronicsReplies: 4Last Post: 23-02-2013, 09:36 PM -
VFD (?) tripping RCD
By Jonathan in forum Spindles & Drive MotorsReplies: 22Last Post: 03-12-2011, 08:19 PM
