Thread: Laser PSU tripping RCD
16-11-2020 #4
Thanks for the replies.
After returning to the workshop I realised that I had the machine plugged into a plug socket that is on the lighting ring and not into a socket on the power ring.
This ring has a 20amp fuse and when i turned on the machine it did not pop the breaker.
Previously when it was tripping the PSU was connected by only the L N and earth, I had disconnected the tube and taped up the wires with HV insulating tape.
Obviously I want this to be safe, would you still recommend removing the PSU and testing with the separate mains feed?
Redsail M500 mini laser engraver needs a new laser tube ???
By shindax in forum Laser Machines & BuildingReplies: 4Last Post: 12-10-2019, 02:21 PM -
VFD Tripping an RCD
By Washout in forum Spindles & Drive MotorsReplies: 13Last Post: 04-09-2017, 02:07 PM -
RCD tripping
By Saracen in forum General ElectronicsReplies: 6Last Post: 22-01-2017, 12:52 AM -
RCD tripping
By motoxy in forum General ElectronicsReplies: 4Last Post: 23-02-2013, 09:36 PM -
VFD (?) tripping RCD
By Jonathan in forum Spindles & Drive MotorsReplies: 22Last Post: 03-12-2011, 08:19 PM
