    Do you have those moments when you think you have done something neat, and then you realise it really was a bit stupid?
    I had a stepper motor with a 5mm shaft and a coupler with a 6mm hole. I got a piece of 6mm brass rod on the lathe and drilled it 5mm to make a tube shim. the other shaft is 6mm anyway and when I tried it on the coupler I realised it was a 6mm to 1/4" converter, so I got a piece of 8mm brass rod and turned it to 6.35mm and drilled it 6mm, making a delicate tube with a wall thickness of 0.17mm.
    I was pleased with that, then I thought - Ey up, why did I not just stick the 6mm shaft in the 6mm 'ole and make just one quarter to 5mm adapter - Doh 🤦*♂️🤦*♂️
    Cheers,
    Rob
    (getting older, getting fatter and getting stupider)
    Rob.
    Join the club
    Lives in Plymouth, United Kingdom. Last Activity: 11 Hours Ago Has a total post count of 1,746. Received thanks 297 times, giving thanks to others 11 times.
    It's the "when the cat has kittens you have to add another, smaller, cat flap" syndrome.
    It happens - and increasingly often for some of us...
  1. Losing steps/position, again
    By ngwagwa in forum Artsoft Mach (3 & 4)
    Last Post: 30-04-2020, 12:23 PM
  2. Losing steps
    By Edendale in forum General Discussion
    Last Post: 06-03-2020, 10:10 PM
  3. Losing steps on Z axis
    By Arzo10 in forum Machine Discussion
    Last Post: 31-03-2017, 10:49 AM
  4. New Mill losing steps
    By lukecnc2012 in forum Gantry/Router Machines & Building
    Last Post: 08-11-2014, 02:56 PM
  5. x-axis on Orac losing direction
    By asto in forum Motor Drivers & Controllers
    Last Post: 29-03-2013, 01:22 AM
